Microtech LT-8....I need some plugs.
Started by captainbizzaro, February 20, 2011, 06:28:04 PM
captainbizzaro
So I\'ve bought a Microtech LT-8 and hand controller for my conversion but it only has the main centre plug with it. I\'ve emailed Microtech direct but does anyone have any experience with this issue? Can you get the plugs seperately as I\'d have thought this is quite a common situation when swapping ECU\'s between various cars.
Any thoughts?
12at
what centre plug you talking about??
the loom plug or the handset cable / plug?
captainbizzaro
The loom plugs, I only have one of them.
12at
The microtech loom is not terminated. it only comes with the plug that goes into the ecu.. you just use the  standard plugs on your water temp sensor, air temp and injectors.
captainbizzaro
Yeah I know that, it\'s the multi pin block plug at the ECU end I need. I can buy a set direct from Microtech for $45 Aus and a complete loom for $165 but want to know if I can source one in UK first.
12at
best to get a complete loom from jon at microtech or better still buy my lt10s & x4 box that comes with a terminated loom  :)
