Engine Electronics
Started by MintyFresh, February 29, 2004, 05:12:54 PM
MintyFresh
A couple of questions about the electronics.
Im planning on installing an Apexi Power FC and Commander to my FD, and i want to get a Greddy Profec E-01 as well.  Would there be any problems with these?  I only want to use the Greddy unit boost control as i like the screen.
Also, I want to install a Defi Link Display for monitoring oil pressure/temp, water temp, fuel pressure etc....  Am i right in thinking that i need the Defi Control unit to use this?  and is the Defi control unit all i need to monitor everything on the Defi Link Display?
Thanks in advance
Dean
MintyFresh
someone must know about this stuff?
g11ary
The best person to ask this is the place you intend buying Defi from, but from memory, you will need the control unit but you will also need the virious sensors to read what you want via the defi link display, you chose what you want the display to show.
kevint
On the Defi questions I would talk to Nito or Jane at //www.defi-shop.co.uk  They really know their stuff on the Defi products.  I think Gary is correct that you will need the control unit and appropriate sensors.
Kevin
kevint
I should also add don\'t just use Nitosport for free advice, apart from being nice people they are trying to run a business so consider buying from them if you are to use their expertise.
Kevin
