basic maintenance activities
Started by P44CKO, December 18, 2010, 04:58:25 PM
P44CKO
Hey guys,
bought my FD on monday and after going through the service history and checking over engine bay, have decided to carry out some maintenance activities before getting it up and running on the road.
going to do the following:
oil / filter change
coolant change
full belts change
my main question is, how easy is it to change the belts how many are there and do you have to worry about any timing issues? or is it it literally a swap and tension afair ??
thanks in advance guys, want to save my money and do most the work myself
philiwily
The 2 belts are easy to replace, just don\'t over tighten. Might be better changing the fuel filter if it hasn\'t been done lately.
Stick a set of plugs in also as they really don\'t last long.
SiH
Belts are fine, main thing to remember is to loosen the idler pulley when trying to slacken off the tenioner bolt. Trust me on this...
Change the fuel filter too - oh, and it\'s a complete arse - hidden above the diff.
P44CKO
cheers guys, sounds pretty straight forward, going to do fuel filter + spark plugs too, probably put magnecor ignition leads on at the same time
trotter
Quote from: P44CKO;733182cheers guys, sounds pretty straight forward, going to do fuel filter + spark plugs too, probably put magnecor ignition leads on at the same time
good luck, HT leads are a ballache to do!!! I had to dissassemble half the sodding engine to get the top sockets out!!!! :)
graeme
Work hard, play hard house :D
P44CKO
guys, ive bought this type of antifreeze to mix up with de-ionised water, but not sure whether its the correct stuff. Can someonbe advise?
ALPINE ANTIFREEZE EXTEND:
Monoethylene glycol based automotive antifreeze and coolant utilising Organic Acid Technology (OAT). Used in all diesel and petrol engines, suitable for all year round use. Protection from freezing down to –40°C and superior corrosion protection for all metals found in the cooling system. Extra long life – up to 150,000 kms or 5 years whichever occurs first.
its red if that helps ?
