removing tar with dry ice video help
Started by dr50376272, December 08, 2010, 06:32:46 AM
dr50376272
my dry ice removal help video: http://www.youtube.com/watch?v=PHH0g78lQ1I
look at all my rx4 coupe restoration videos :-)
have a nice day
david
1990_fc3s_t2
Dry ice is not readily available in the uk although i\'m sure if anyone wanted it there maybe is some places that sell it??
I removed a load from the floor pan before welding last winter and it was cold enough to make it chip off in big pieces and pretty easy to do.
Minus 10 degrees here in places so don\'t think many will be heading out to find dry ice :rollin
trotter
think nightclub smoke machines ;)
if you happen to know somebody in the NHS - specifically the blood transfusion services like me dad, you can get it no problem ;)
Work hard, play hard house :D
MaLicE
nightclub smoke machines use liquid not dry ice...
SiH
I accidentally peeled off a crapload of my deadening yesterday just by pulling a stud from the boot floor - it\'s so cold here in the UK at the mo it basically falls off!
dr50376272
sounds fantastic ! i hope everyone watched my video for some idea of what it takes
trotter
Quote from: MaLicE;731921nightclub smoke machines use liquid not dry ice...
correct, I admittedly meant older style stage ones that IIRC did use dry ice!!
Also, local school/uni chemistry departments can sort you out if you have \'a contact\' :P
AtomicRex
If people need dry ice....not really that necessary at the moment, I can get hold of it!  You need to use it pretty darn quick though.....but you can strip a shell in about 4 hours!
Its about £100 for a bag, but will only last about 6-8 hours.  It is very easy though...sit the dry ice on a patch and leave for 10-15 minutes, move to the next patch and then work on the previous one.
Dualist
Quote from: AtomicRex;732004Its about £100 for a bag, but will only last about 6-8 hours.
How many kilo is that for.?
I get mine from http://www.cleansurface.co.uk/dry-ice-supplies/ and bags of 3mm pellets are.. 10KG - £37.01 Inc VAT Delivered or 20KG - £48.18 Inc VAT Delivered. (I use it for overclocking pc\'s).
AtomicRex
Cheers for that....excellent price!  Although ours were for 25kg bags....still is a lot cheaper!
