Vac line routing
Started by Koose, September 17, 2010, 07:25:04 PM
Koose
Hi folks
The boost valve meter thats bolted on the forwards side of the drivers suspension turret, mine had a vacuum line then 10" later a t piece with a 4" vac hose on each end, where do they go ?
Ive removed my acv and egr.
Mark
Probably the recirc valve on one end and a vacuum source (nipple on the air control valve normally) on the other.  As you\'ve taken the air control valve off, you can probably use the nipple that sticks out of the Upper Inlet Manifold below the BAC valve as a good source.
Koose
Exactly what i was hoping, as thats what i did :D
Cheers Prof :D
