Rear suspension bushes/kits
Started by rossonza, August 30, 2010, 01:47:55 PM
rossonza
Right, finally got round to measuring the bushings on my suspension/rear end that need replacing. I\'ve got the following dimensions, If anyone can spot anything wrong let me know.
cant remember
14m internal diameter
Est 46m external diameter
40m deep
need 8 of those
 Shock bushing
12mm internal diameter
28mm external diameter
Metal sleeve 32mm deep
Width of bushing 24mm
Need 2 of the above
 All above metal sleeved
Roll bar linkage
8mm internal diameter
25mm external
10mm deep
Pure rubber
8 of those
 Side to side dif linkage thingy
12mm internal
30mm external
40mm deep
Metal sleeve inside metal bush
Need 4 of the above
 Roll bar bushings
15mm internal
30mm external
25mm deep
Need 2 of above (see photo)
(D shaped)
Are there full kits available? i\'ve looked on the net today for a while and i cant find anything really. Is it worth Poly\'ing? im sure its going to be very expensive to get all those made.
Thanks!
Ross.
email @ rossonza@gmail.com
1984 FB series 2 in gold
JBerg
captainbizzaro
As above, email Billy at respeed he responds quickly everytime and ships over here. Or try Clive, he might do kits but I\'m sure he\'d point you in the right direction if not-clicky on his banner up top and it\'ll take you to it.
You don\'t want to go 100% poly though-you need to get some standard type as they are designed to have a bit of give-can\'t remember which struts that applies to but I\'m sure someone will tell you.
shaunwil
The polybushes seem to be very good. Been running full polybushes for over 12 months without any hassles.
The full kit isn\'t silly money either !
Shaun
captainbizzaro
Quote from: shaunwil;713915The polybushes seem to be very good. Been running full polybushes for over 12 months without any hassles.
Shaun
Who was that from and how much?
shaunwil
The respeed Energy ones. Could be nearer 2yrs of use thinking about it becase they cost 100 ish all with postage and the dollar was almost 2 to 1 !
Shaun
rossonza
Im over in the USA in October so may see if i can get them sent to me there, then bring them back in my case.......... doubt customs would have a problem. Ill be at penn state, any ideas where respeed are based? looked on the site for contact us but didnt notice a full address or ZIP?
captainbizzaro
Did you leave any of yours with standard bushes or are you 100% poly.
That was a mistake letting us know about that Ross, you better take an empty suitcase with you as I want the ReSpeed coilover kit haha.
shaunwil
I swapped all the bushes in the full kit. Don\'t think there was much of the original stuff left !
Shaun
rossonza
http://mrcmfg.com/catalog/product_info.php?cPath=112_41_91&products_id=153
that looks like the right kit to me! $160 doesnt sound too bad to me either. What you guys think?
haha Tim :P
