fd altenator fitting
Started by francovel3, June 19, 2010, 01:54:52 PM
francovel3
ok its my first time fitting a new altenator so does anyone have any advice with the changing over?
POWER GAINS
slingo
its very simple dude,disconect your battery 1st .....should take you 20 mins tops
jackaleks
just undo every bolt you can see and pull it out, it has two connectors to remove as well. i also had to use a large screwdriver to \'coax\' it out.
francovel3
Quote from: jackaleks;700705just undo every bolt you can see and pull it out, it has two connectors to remove as well. i also had to use a large screwdriver to \'coax\' it out.
yea thanks me and my bro done the same thing you said this morning
POWER GAINS
