Where can i get semi/rigid diff mounts?
Started by James H, May 24, 2010, 06:24:50 PM
James H
As above after a set of semi or rigid diff mounts for the fc, thanks!?!
monterx7
88 gxlt US spec
86 egi UK spec
James H
Just found them my self, but doing the diff swap a week saturday but thanks matey. Im also interested in the snubber idea.
AtomicRex
If you are happy to send me your diff mount...I can send you one with Powerflex bushes in place...brand new ones...
I think the bushes are about £21.95 each + VAT + Postage...
Either that or I have them loose and you can fit them yourself :)
James H
Sounds great to me, am heading up to bristol on wednesday/tomor so if ok i\'ll call by with the housing & we\'ll swap then, if ok how much will you want for it then, thanks?
James H
Also are you familiar with the a snubber set up on the underside of the car, it then sits in between that & the diff, prob gonna do this as well, whilst the diff is off!?!
monterx7
i remember seeing write-ups on the snubber mod but that was some time ago.  but i believe it was simple especially with the diff out
88 gxlt US spec
86 egi UK spec
AtomicRex
Not aware of the Snubber method.
Will be down the workshop all day tomorrow...so pop in and say hello.  Post code is SN12 7QT give me a ring if you get lost :0
James H
Sounds great, what number unit are you? & how much :) thanks?
James H
rx jamie
clive does them mate. done me so beauty ones.  alloy on the outside and nylon in the middle. totally rigid but without all the vibration.
MaLicE
there is a guy on ebay that does the high speed air temp sensors that does alloy ones i think
James H
