squealer pipe?
Started by super7, May 21, 2010, 07:14:21 PM
super7
any 1 got 1? or no the cost to have one fitted?
also some ppl say the ruin ur car others say its a myth?
but they sound hella cool :Giggle
MaLicE
what?
are you on about screamer pipes? if so you will need to go for a single turbo and run an external wastegate plus all the ecu and mapping etc to make it work, it wont be cheap... there are many more reasons to go single than just a screamer... providing thats what your on about.... but tbh im not sure it is? maybe a bit more info would help.
oliverash
assuming you have all the bits in place as stated above it wont cost much - literally just a bit of pipe a few inches long.
makes a pretty impressive sound but not advisable for those with sensitive ears!
Before the screamer mine just vented into the atmosphere which i actually prefered the sound of although i believe thats not recommended depending on who you talk to
skybusr34
i dont think it does any damage apart from ear drums. only damage i can think of is if you had rex converted to screamer pipe from having wg plumbed in. not having ecu remapped as it would make it run lean.
L18M
if you get flames from the screamer then maybe a little bit of a toasted engine bay (or similar area) does depend where the pipe exits
dthebuk
if you\'re going single turbo, definitely get one.
they\'re absolutely awesome
:burnout
