fibreglass doors
Started by patrickg293, May 02, 2010, 09:05:55 PM
patrickg293
does anywhere know where you can get fibreglass doors or even if they can be got, carbon ones are a bit pricey for me at the moment, cheers patrick:3gears-rh
karting
i think atomic rex make them aswel las the carbon ones?
rx7boy
Quote from: patrickg293;691134does anywhere know where you can get fibreglass doors or even if they can be got, carbon ones are a bit pricey for me at the moment, cheers patrick:3gears-rh
give steve rivett a buzz as I know he has a contact who makes them, as he had some made for his track cars
say Dale put you in contact
contact is zero 7795967850
DM-Motorsport.co.uk
gavink
What sort of cost are fibreglass doors?
karting
Quote from: gavink;691292What sort of cost are fibreglass doors?
i dont know the spec of your car, but if you buy fibreglass doors then you NEED a roll cage
chrisJDM
fibreglass doors, sounds interesting!! as stated would need a roll cage first thou DOH!!!
AtomicRex
we do sell Fibre glass doors.
They are an excellent fit...brilliant shut lines too!
As pointed out, you need a roll cage!!  I won\'t sell Carbon or GRP doors unless you do, as it is a big apature to fill, and you will end up with a car on your lap if you were T-boned!
The doors are 2 piece and bonded together, and are extremely light!
GRP doors are £500 + VAT each (£587.50)
Carbon doors are £900 + VAT each (£1057.50)
We can do a hybrid option which has a Carbon outer skin and a GRP inner skin £750 + VAT (£881.25)
gavink
Quote from: karting;691311i dont know the spec of your car, but if you buy fibreglass doors then you NEED a roll cage
Yeah i know was just interested to see the price compared to carbon doors :)
