What sparkplugs?
Started by NeilSR, April 27, 2010, 02:56:37 PM
NeilSR
What spark plugs should i put in the fc?
G@NDY
Depends on the tune etc. At the minute ive got NGK 7\'s and 9\'s for the run in after mapping I will be running 10\'s and 11\'s.
NeilSR
Tis just a basic tune, filter, dump valve, exhaust, nothing major
HaywardRotary
Just use NGK BUR9EQ and you\'ll be fine.
Reagrds
Carl
Single turbo conversions.
S
12at
I always use NGK B9EGV never had a issue
Same here - they are basically the stock \'Trailing\' plug - works fine in both holes ;)
pdtaylor18
9\'s all round for me too, will only swop when I really need to or if my eventual rolling road tune picks it up.
Email: pdtaylor18@hotmail.com
Pete[SIGPIC][/SIGPIC]
NeilSR
Big thanks to everyone for the advice, went with the NGK BUR9EQ and it started straight away, Im a happy man now!
G@NDY
Furb
had the 9\'s in at first.
when i started upgrading i went over to b9egv\'s because i had spark and detonating issues. i now run the Greddy RE-10.
bit pricy but they work way better then the b9egv\'s, which in turn are better then stock. they also last longer...
L18M
Quote from: Furb;690706had the 9\'s in at first.
how often do you change the greddy plugs?
