gearboxes...
Started by Ian65, May 21, 2010, 10:20:25 PM
Ian65
am I right in thinking that the ratios are the same across all 3 series.. 1,2 & 3?
Does anyone know of any differences?
kiwimazda
AS far as I am aware yes unless someone else knows better.
What are you after. Close ratio?
Long 1st Gear?
Brian
David Nock (RIP)
I seem to remember reading that the oil level was raised on the later boxes due to oil starvation in 5th gear on motorways. So Mazda drilled the plug position higher....simples.
That does mean that earlier boxes may have suffered oil starvation though. Was the S2 higher position or lower? Don\'t know.
Sadly Missed
shaunwil
I was told they are all different on the outside as well and aren\'t interchangable. I have an S2 box in the garage that isn\'t much use !
Shaun
kiwimazda
Ah yes me thinks you are right. I think the S1 is different even to look at
