Need a fiberglass bonnet, where from??
Started by ninjasx, June 27, 2009, 05:36:39 PM
ninjasx
I need an aftermarket fiberglass bonnet for the FC, who supplies them in the UK, the cheaper the better:Thumbsup!
92 FD3S Type R
94 Nissan 200sx S13 drift project
95 Nissan 200sx S14 Veilside with 350+bhp
ninjasx
92 FD3S Type R
dthebuk
what kinda set up you running?
If you still have a top mount its probably worth just picking up an ally bonnet from a cab.
Other than that try rotaryart. Google it, im not sure of the website
:burnout
ninjasx
Thanks! It`s running a front mount so need to ditch the forward facing bonnet vent.
92 FD3S Type R
dthebuk
ok cool. Ive only ever seen one other bonnet on an FC. LI8M on here has one. hopefully he\'ll point you in the right direction
:burnout
L18M
the right direction....
umm.. jus keep an eye out on the for sale thread.
tho i had a front mount and stock hood. air still flows under the car so is still ok.
or u can go egi bonnet. its only v-mount reli that need vented..
speedline imports had one going but sold already i believe.
http://www.mazdarotaryclub.com/forums/showthread.php?t=58365
(quite like that stype hood)
otherwise its a case of import.
rotaryart do a cover to cover the front hole in stock hood but cost like 100 which i think is bit ott
hope this helps.. tho think i jus been jibbering 1/2 the time lol
G@NDY
Is there anyone in the uk actually selling a fibreglass bonnet for less than £500?
Im getting fed up of looking !!!
Quote from: G@NDY;687913Is there anyone in the uk actually selling a fibreglass bonnet for less than £500?
Im getting an EGI bonnet and cutting rear facing louvres in it :)
G@NDY
I have looked into that matey, but thought bonnet £50 delivery or petrol to pick it up £50 paying for louvres or modification £100 then getting it sprayed ££££ i reackon around £250 and its still going to be a heavy steel bonnet.
There must be fibreglass bonnets out there around £300 surely?
Quote from: G@NDY;687959I have looked into that matey, but thought bonnet £50 delivery or petrol to pick it up £50 paying for louvres or modification £100 then getting it sprayed ££££ i reackon around £250 and its still going to be a heavy steel bonnet.
I am thinking if I can get a aluminium one and then cut away some of the ribbing underneath that might be ok, although I am looking at getting a uprated uprated top mount now for the T88 lol so I can use the OEM bonnet :Giggle
You might even be able to just make your own with an EGI bonnet, some triangle chocks of wood and lots of fibreglass lol
