power fc\'s?
Started by ENVYD, April 14, 2010, 11:41:42 PM
ENVYD
what’s the fault?
when i turn my ignition on, the water temp dose not read on the commander and the heat light stays on, on the dash! i have a feeling this is stopping my car from starting?
as before i tuck it off road, while i was driving, if the above symptoms happened, the car would start running ....e! so have a feeling there is some type of short or something and now stopping he car from starting at all!
thanks
Steven
ENVYD
neil_jdmr
Someone on here had a very similar fault with their commander showing --- where the temp figure should be a little while back, This is the exact same fault as Steven is getting above.
Edit: Found it
http://mazdarotaryclub.com/forums/showthread.php?t=58515&highlight=water+temp+reading
