longer studs?
Started by ENVYD, March 22, 2010, 05:36:02 PM
ENVYD
anyone know who makes longer studs for the FD as i want to run some 10mm spacers ( with my et12 wheel :D ), and my stock studs are too short!
thanks
steven
kev-yorks
Clive mazdarotaryparts will sort you out for sure.
Regards Kevin
ENVYD
SiH
Warning: Rear is an UTTER ballache :(
ENVYD
What, to get ther studs out?
nuki
can you not use some hubcentric spacers? rather than extending the studs?
DM MOTORSPORT\'s Sell good quality cheap spaces on here!
ENVYD
Not really bud, a M12x1.5 stud/nut requires a min of 6 turns and the stock studs with 10mm spacers only turns 3 times, so the nuts hardley go on!
SiH
Bolt on\'s are no good for 10mm unfortunately Nuki - the original studs stick otu too far, you\'d have to chop them right down :( And as above, not a chance of getting them on on stock studs with slip ons.
Envy: Swapping front studs is fine, but on the rear you have to completely disassemble the hub (unless someone\'s found another way) including pressing off the ABS ring and removing the bearing (which means fitting a new one) IIRC.
nuki
20mm spacers with super stretched tyres ;P
mx1311
si is correct, ballache
SiH
I\'m going to have exatly the same issue as you Envy.
I\'m about to mount 9.5 et25 on the rear with a 235, and a rolled lip - you could fit a bus between arch lip and wheel. I can\'t wear that, I\'ve got a reputation to uphold. It needs about 15mm of spacer, but no real way to do it without stud monkeying :(
I think I\'m going to have to 20mm and try and get a bit more of a flare on the rear, but I don\'t want to change the arch profile :(
