Project resurrect Innovate unit...
Started by Prof, August 29, 2010, 03:26:50 PM
Quote from: philiwily;715137Hi Prof. Thanks for that, never thought about the decimal point looking like an 8 if it was too fast.
I have been reading some tutorials and and im getting there but got a bit stumped I have assembled the 2 .asm files but the value table needs to be a .inc, can you point me in the right direction.
Phil
Hi Phil - just rename the lookup table file - I had to call it a txt file to load it on the site :(  It is a .inc on my pc...
I\'ve loaded up the lcd wiring diagram here as well.
philiwily
Thanks for the LCD diagram, perfect.
I tried that but now im getting lots of 113 errors.
Error[113]   C:\\PROJECTS\\AFR_METER_MAIN\\AFR_METER_CODE.ASM 65 : Symbol not previously defined (PCLATH)
Error[113]   C:\\PROJECTS\\AFR_METER_MAIN\\AFR_METER_CODE.ASM 99 : Symbol not previously defined (HELLO)
Error[113]   C:\\PROJECTS\\AFR_METER_MAIN\\AFR_METER_CODE.ASM 102 : Symbol not previously defined (AUTHOR)
Loads of these:D. I will leave it for a few days and let what i have learned sink in.
Don\'t leave the country:D
Phil
The code is in 2 parts, one part is the actual code, the other part - which has an include for that - has most of the definitions for variables.
Make the one with the variables the \'main\' project file, and then make sure that both the other files - the actual code and the table file have the same name as represented in that main file that includes them - if that makes sense.   I probably should have zipped up my directory - I\'ll do that when I get home tonight - as it has the project file for mpasm already there - and you can just click on \'build all\' and watch it compile ok :)
By the way - it will work with or without an LCD - and although it\'s coded for an 8x2 it will work with any 2 line lcd - it will just be squished up one one end that\'s all.  Without an LCD you still have 2 analog outputs:  0-4.7v and 1-0V (the latter will drive a standard \'cheap\' AFR gauge).
philiwily
Hi Prof.
My PICKit3 arrived today. Any chance you could send that zip to me.
My email is philipglancy at hotmail.com
Cheers Phil
