Where to source parts for rebuild?
Started by suba, March 16, 2010, 10:27:54 AM
suba
Now that my engine has been stripped down I need to start buying bits for the re-build - I need to source this lot with genuine mazda parts (apart from the apex seals):
FC gasket set including water seals
stationary gear bearings
rotor bearings
set of oil control O rings
set of corner seals and springs
set of side seals and springs
set of PTS apex seals (not sure if 2mm or 3mm are the ones to go for?)
I also need a rotor and housing - but I\'ll get those from Tim at RX Motors.
If anyone could advise me of the best places to order that lot I\'d be very grateful.:mmmm
Single Turbo time!
12at
Full rebuild kit is best to be purchased from AUS i would say for about $1400 which will give you everything from oil control rings and springs, gaskets, side seals, apex seals and springs, corner seals the works
BlitzBoy
Rotaryarts or Dragon  have Mazda rebuild kits normally in stock, Rotaryart are the UK dealers for PTS seals
Rotorstock winner 08,09
New Project
"el fénix" RX2 by Mark & Mark
suba
Thanks - I\'m not keen on ordering from abroad as I dont think I\'m going to save anything with import duty and the exchange rate as it is.  i also have a lot of hasstle if any wrong bits are sent etc.:Thumbs-up
Single Turbo time!
You can\'t run 3mm seals unless your rotors are milled out to 3mm - so im guessing that makes it an easy (and probably cheaper) choice for you :D
TRIND-FD
Cant tim supply the whole lot. Would of thought he could.
V8 fd\'s rock :cool
