Rebuilding done!
Started by manux86, March 14, 2010, 11:23:43 AM
manux86
Ok I finish my rebuilding yesterday and the 13b was started at first turn of the key. I have only a problem. The tachometer, the speedometer, the odometer, the water gauge and the oil pressure gauge dont\'work. Only when, at idle, I turn steeringwheel a few on left the work for 1-2 second and then they stop to work.
What can it be??
thank you
rx7boy
Sound like a loose connection behind the dash, best bet is just to check it all got solid connection round the clips and the actual gauges themselfs. Oh and congrats on the rebuild, especially with first turn of key start !
DM-Motorsport.co.uk
manux86
Thanks for congrats..:) I check immediately what you said.
manux86
Ok I found a large connector white near ecu that don\'t was connected, but when I connect it and I turn the key on, the cluster start to non-stop beeeeeeeeeep and I don\'t know how it means..water and oil are full, what can it be now? Besides after this I tried to start the motor but It start limped and with strange noises.
DR SCHNITZEL
water level low, check you engine bay connectors and add water to taste.
manux86
Yes but water level isn\'t low. And connector level are well connected, the prolunged beep alwais means low water level?
Quote from: manux86;679024Yes but water level isn\'t low. And connector level are well connected, the prolunged beep alwais means low water level?
Its the coolent buzzer/rev limit buzzer, I guess if the ECU thought it was over 7k rpm it might go off, but most likely its coolent. Don\'t forget that when cold the water in the rad isn\'t being used, did you get all the air out of the engine block as well? it might be an air bubble trapped there, which is what mind had.
manux86
How can I understand if the water level sensor is dameged?
rx7boy
Quote from: manux86;679570How can I understand if the water level sensor is dameged?
If you earth it, then the buzzer will stop sounding !
DM-Motorsport.co.uk
