water seal kit is it complete
Started by redgti, March 10, 2010, 09:39:09 PM
redgti
http://cgi.ebay.co.uk/MAZDA-RX7-RX-7-FD3S-13B-ENGINE-O-RINGS-SET-N3A1-10-S60A_W0QQitemZ200437954722QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item2eab0878a2
i have seen this is this enough to do my waterseals i am hoping to keep all the old metal seals as in apex, side and corner as compression is good. what do people think?
redgti
anybody have an answer??
Is this a full soft set of seals??
RobbieRX-7
It is yes, but it\'s £130 too expensive. These should go for between £120 and £150
SiH
Quote from: RobbieRX-7;679449It is yes, but it\'s £130 too expensive. These should go for between £120 and £150
Mine was £225 delivered (Plus tax) from RHDJapan, and that was the cheapest it could be found :)
HaywardRotary
Quote from: redgti;678195http://cgi.ebay.co.uk/MAZDA-RX7-RX-7-FD3S-13B-ENGINE-O-RINGS-SET-N3A1-10-S60A_W0QQitemZ200437954722QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item2eab0878a2
At least change your apex seals while your there.
Regards
Carl
Single turbo conversions.
S
redgti
Quote from: HaywardRotary;679460At least change your apex seals while your there.
Regards
Carl
http://www.rotaryaviation.com/overhaul_kits.htm might just have to go for their kit insted comes with everything i believe i need.
The thing with my engine is it starts perfectly hot or cold, but the coolant hoses pressurise. So i am hoping i can reuse all the engine parts as long as one of the irons hasn\'t cracked or rotted through on the seal grooves.
nuki
My water pipes used to pressurise but it was due to previous owner(s) bypassing the expansion tank because the AST was broken. i got the AST removal kit and fixed the issue. Pipes no longer bloon.
redgti
yeah i have fitted the ast removal and a 0.9 bar cap and connected that to the overflow tank and the pipes are definately balooning. so this has to be water seals on their way out doesn\'t it.
nuki
What pipes are you using? i had some thin wall\'d cheap silicone hoses and they used to just bloon before i changed them too.
You can buy a testing kit that takes a sample of your coolant and tells you weather compression gasses are found in the water.
There are a couple of diagnostic options before you should rebuild.
Champaign test is one of them.Another is an engine pressure tester which takes your water system up to pressure and you monitor for pressure drop on the gauge.
Speedworks
I only see the black (inner) water seals on the picture. not the orange (outher) water seals
