Boot battery mounting stuff?
Started by probedb, February 18, 2010, 05:08:31 PM
probedb
Hi all,
I have my battery mounted in my boot now using a boat battery box, Steve G did the work and recommend I get some mounting kit?
I\'m not sure what I need. I\'m guessing something to properly attach it to the car boot and hold the top down?
Cheers!
Paul.
karl_tate
yeh you need to get it bolted down, if you happen to crash you dont want a missile, in the form of a battery flying around in the cabin :eek:
have a look at my rebuild thread on how i bolted mine down.
HTH
____________________
XBOX GAMERS TAG --- tatey1985
probedb
Cheers Karl :) I\'ll ask Steve about it when I pop over on Saturday.
Jono FD3
The other option is to do what I did ;) again take a look at my project thread.... I basicaly used a decent ratchet strap & bolted it down using the rear seat mounting brackets. whent over the battery & lower section of the box, then used the loose end of the strap to secure the top & tied the slack around the rear strut brace ;)
Jono
probedb
I\'ll ask Steve exactly what it\'s bolted too and what I need to get to fix :)
