Anyone done the steam cleaning maintainance?
Started by m1tch, February 12, 2010, 10:20:28 PM
Hi all,
Just wondering how many people have done this:
http://www.rotaryresurrection.com/2ndgen/tech_water_injection.html
I know its like what happens with WI lol but a bit more extreme!
rx7boy
Seems interesting, will subscribe to the thread to see what others think, does seem a bit of bodge job but who knows !
DM-Motorsport.co.uk
1990_fc3s_t2
Ive not done it yet, but only read good things about it on rx7club
Im also intrested to know how many people actually do it here and how often
I might do it on mine, although maybe not that much water lol and after I fit better igntion then maybe I will lol although I could just fit my WI and do it that way :)
ashc
i was going to try it when my compression hits about 6.5 and then remeasure it lol
jackaleks
hmm.
i think i\'d rather just buy a WI kit. what happens if you let too much water in by accident/inexperience? i\'d rather not test whether my engine can hydrolock or not.
1990_fc3s_t2
It gets sucked through a vacuum tube so you cant get a whole gallon in there at once!
I wouldnt be worried about locking up the engine, just make sure you keep the car running and go for a blast afterwards to make sure all the waters gone.
This doesnt do anything for compression, just cleans right?
Its the atf trick that helps a low comp engine just dont leave it in too long.
Quote from: 1990_fc3s_t2;672547It gets sucked through a vacuum tube so you cant get a whole gallon in there at once!
I\'m guessing that\'s to do with Carbon lock - the ATF eating at the carbon buildup around the seal\'s / springs to free them again and help seal the engine.
1990_fc3s_t2
1990_fc3s_t2
hehe this would be fun too!! :evillaugh
"Yep water works great. Some people even hook a hose up to their washer fluid reservoir; so they can squirt water into the engine with a flick of a lever. Also makes for a great James Bond smokescreen for pesky tailgaters."
SiH
Quote from: 1990_fc3s_t2;672579hehe this would be fun too!! :evillaugh
That\'s the scuzziest, most low rent WI I\'ve ever heard of :D love it :Giggle
Except for the vacuum/pressure being applied at the line to the washer bottle pump...
