does you AP Eng pfc have...?
Started by L18M, January 26, 2010, 05:05:03 PM
L18M
did a little digging around and seems the Ap Eng pfc came with harness, 3 bar map sensor and fd iat.
from what i\'ve discovered (and a few others) the ap eng has a different sticker on the chip inside "13b1" (fd is sth like 13B-REW2) which can mean it has a different base map on and few other different software changes.
taken from
http://www.docstoc.com/docs/2300073/FD3S-RX-7-PowerFC-FAQ-Version-13-February-11-2007-Written-by
pdtaylor18
Did you fit your 3 bar sensor? It will not run if it has been programmed with a 3 bar in its setup as all the settings are completely different. If you initiate the ECU then try a standard TII boost sensor as this may work. If not then send me the ECU and I will try in mine. At least I can use my datalogit and see what is in the map. I can also load a decent map which will better support your mods to make it a bit safer. I doubt the standard setup will cater for a huge turbo like yours.
Email: pdtaylor18@hotmail.com
Pete[SIGPIC][/SIGPIC]
L18M
thanks pete, the turbo is not that big :(
james said he plugged in the 3 bar map sensor in etc and checked settings but he not really used apexi before, just microtec mainly.
should get the loom within the next couple of days, just waiting for customs then will see what happens or not lol
i might just take u up on the offer of posting u my pfc if james still cant fire it up :(
i\'m hoping its just the settings he not got right rather than the pfc playing up.
