Rear Window Seal
Started by Gatesy, January 17, 2010, 06:24:26 PM
Gatesy
Hi Guys,
Took my FD out for a blast today for the first time in about 2 months and noticed that I had about 2 inches of water in the boot and when I opened it up water was pouring out of where the struts go up into.
I\'ve emailed MRP but just in case they can\'t get them for me does anyone know anyone other than Newera (they haven\'t got them listed and they are stupid money if I remember correctly) I can get one off?
J_T
Not sure where to get replacement seals except rotaryart
http://www.rotaryart.uk.com/acatalog/New_Mazda_RX7_3rd_gen_ext_body_styling.html
I\'m interested in this thread as I get a similar issue but it only happens when I open the boot after rain.  It seems to collect in the rear hatch weather strip where the ends meet and then empties upon opening.
Where are your joins in the seals?  Do new seals come molded to shape or could you move the ends of the seal to somewhere that will not collect water?
batman
when i resprayed mine i nearly gave birth when mazda told me how much the new ones were. so i had a company near me use a seal he had recond would fit and its worked perfectly if you get stuck and can make it to here i can put you in touch company is called top glass
McC
i have the same problem, when i park on the slightist of slopes i can see water coming in through the boot, and then when i open the boot water pours out on to the rear seats on the passenger side. Its really annoying when you have just spent the bst part of the afternoon cleaning the thing!
ENVYD
ah poo, i need new front and rear seals for my windows :(
fil_auto
yep - another FD owner that suffers with this, almost identical scenario to the first post! Gonna have to find somewhere to store her rather than outside! Then hopefully wont\' have to worry so much about the water! ;)
JBerg
+1
Opening the boot after a rainy day, it pours out between the boot trim/struts
Wasnt too sure what the best way to fix it was...
cyman
i get this aswell but have heard that the rear wiper can leak where the seal gets old and this puts the water straight behind the interior plastics. not sure if this is the case with you but i suppose it wont hurt to check.
cyman
Quote from: J_T;665935Not sure where to get replacement seals except rotaryart
i messaged rotaryart about one of these seals about 4-5 days ago as there isnt an add to basket button on it. still havent heard back so dont know if he can get them or not  :(
batman
water pouring into the car when you open the hatch it just a design fault they all do it just runs off the edges of the tail gate and into the plastic qtrs .
jackaleks
i got so fed up with this i just took all of the plastic trim off of the hatch, now it just soaks the boot carpet :( i need a cover...
Gatesy
Quote from: batman;665940when i resprayed mine i nearly gave birth when mazda told me how much the new ones were. so i had a company near me use a seal he had recond would fit and its worked perfectly if you get stuck and can make it to here i can put you in touch company is called top glass
I may take you up on that mate.  I\'m going to try my local friendly garage and see what they suggest after I take all the cowling off of the boot and see if there\'s any clear gaps I can seal.
N777CK T
would you say this is the main place where moisture gets into FDs?
what about door seals? how much can you get them from and where?
