Urgent Help Please
Started by MrHanky, April 09, 2010, 08:31:20 PM
MrHanky
Hi,
Just doing what I thought would be the easiest bit (brake pads) and have a problem.  On the drivers side caliper the inner pistons will not budge and look to be totally seized.  I manged to just wedge the new pads in but now the pads are permanently on disc and too make matters even more fun the caliper looks slightly bent.
Anyone happen to have an old EGI caliper kicking about who is near Leicestershire?  Or any advice?
Trackday is tomorrow morning and now I am beginning to think that I am going to end up wasting £180
Thanks for any advice
Mark
Have you got a G clamp or a caliper piston pusher tool - maybe if you can get the pistons free\'d it should be ok - but could indicate they need a rebuild.
MrHanky
Quote from: Prof;686068Have you got a G clamp or a caliper piston pusher tool - maybe if you can get the pistons free\'d it should be ok - but could indicate they need a rebuild.
Unfortunately they do definately need a rebuild.  Caliper is now leaking fluid and i do not have G clamp or piston pusher anyway.  Basically I will not be doing anything at Mallory tomorrow..... gutted :(
