Confused???
Started by John RX7, January 29, 2010, 06:35:02 PM
John RX7
Hey
Ive noticed something about my blow off valve :2Confused,is it in the right place,it doesnt seem to be anywhere on the intercooler pipes at all,i found it strange as when i had my skyline it was on the pipes,it look like its attached to the manifold,I\'m i losing boost because of where it is,is that the normal for BOV,any advice much appreicated
Nik da Greek
That\'s the same take-off from the turbo Y-pipe as I use for my dump valve take off, mate, so should be a problem. IIRC that\'s where the stock BOV is plumbed from, only difference being it vents into the airbox rather than atmosphere like your HKS one. Doesn\'t have to be on the IC run, it\'s still pressurised, it\'s fine. In theory it should give a tiny bit quicker recover of boost where it is, not that you\'d ever notice
ashc
yeah, mine comes from the y-pipe too, perfectly fine.
John RX7
ok well i kinda want it on my intercooler as i prefer to have it there can i remove it and what do i put to cover it up
