Small problem/ please help
Started by rx7ben, January 23, 2010, 04:15:24 PM
rx7ben
The problem is i cant open the drivers door from the outside. The handle wont move at all, its like its been welded shut. I can open it from the inside and the central locking seems to work ok. Ive had the door card off and it doesnt look like theres anything wrong with the cable, its not loose or anything so im stuck. Its getting really really anoying having to open the door from the passengers side everytime i want to get in the car. Any help would be great.
Aubec
Have you taken the triangle with the handle off to look inside? Sounds like something is jammed inside, could be an easy fix.
Aubec
1995 UK Silver FD
