i need help
Started by gavinnblake, January 05, 2010, 08:24:12 PM
gavinnblake
i have a 1996 Maxda RX-7 Type R Single Turbo T88
just had an Engine Rebuilds from jm-imports the rear rotor getting no fuel :3Confused it has not got mapped on it yet its going to wgt in february
ad4m1
how do u know rear rotor isnt getting any fuel
prob either a stuck injector or leaking o ring if thats the case
What injectors and ECU are you running?
karl_tate
the original map will be on there gavin, why go for a remap??
____________________
XBOX GAMERS TAG --- tatey1985
gavinnblake
as the frunt rotor spark plugs had fuel and the rear rotor had non.
Thats what Jurgen said to do get it mapped
its got 2190.1km on now the rx7 is run ok :3gears-rh just when you go past 4halfe on rev dial it will not let you:Nono!
