map bar sensor????
Started by colin777, December 14, 2009, 12:14:15 AM
colin777
ive got a to4s turbo kit
im going to be aiming for 1-1.2 bar boost with water injection
whats the go with the map sensor do i need to upgrade and where is the best place to order this
cheers lads
L18M
BlitzBoy
you do not need to change the MAP sensor for 1.2 BAR, I would recommend you only need to upgrade to a 3 BAR map  sensor if you are going 1.3 BAR and beyond
Rotorstock winner 08,09
New Project
"el fénix" RX2 by Mark & Mark
colin777
is there any harm upgrading it anyway for 1.2 bar, is it being too precautious
BlitzBoy
No harm, but you have to fiddle about with PIM settings on the Apexi ECU map for the correct settings so you are hitting the correct parts of the map. But your rotary tuner will know how to do this.
New Project
