Seats Again ????
Started by marcusd666, May 21, 2009, 10:46:14 AM
SiH
Ugh! Don\'t get a Carrera! Horrible, horrible seats!
chopper2k22
The Sprints are very comfortable for a fixed back seat, i have them in my car.
and are very reasonable in price too.
Bazza
Sorry to bring this back up but, can anyone who has the corbeau sprint seat tell me how good the fit is, ie does it rub on the door card or is the seat placement offset from the steering wheel :cheers
chopper2k22
The corbeau seat i installed is pushed slightly closer to the trans tunnel and leaves a small mark in the door card.
shaunwil
Running Sparco Sprint V in the FD. Good fit to the tunnel and doors. Only big issue I had was it was way too high with the stock seatbelt pickup. Once running with full harness and lowered they are very nice.
Shaun
AtomicRex
Bazza,
The Sprint seats fit perfectly.  If you run with our seat mounts this will lower the seats to a much more comfortable fit.
If you are interested in running harnesses, we are in the process of manufacturing a harness bar which will also double up as a strut brace.  It will be a bolt in bar and will be fully triangulated!
If you need a competitive quote on seats and harnesses then give us a ring :)
najiru
Interested in the harness bar, when you thinking this will be available?
C J R
Quote from: AtomicRex;652564Bazza,
I\'m also very interested in a bolt in triangulated rear strut brace.
Chris
AtomicRex
As promised!!  A little bit longer than I hoped...but done none the less!
http://www.mazdarotaryclub.com/forums/showthread.php?t=61352
