master cyclender leaking
Started by Adam fc, January 10, 2010, 09:01:11 AM
Adam fc
Recently my brake master cyclender has started leaking.
Its leaking between the resovoir and the metal body \'\'whatever its called lol\'\' and is leaking at a steady rate,top it up once a week.
Can i just replace the rubber seal where the resovoir meets the metal body or is it something more dramatic?
Brett
The big metal thing is the brake booster :Giggle
Assuming you can get a seal kit, then yes, you should bea beltto just replace the offending seal :yes
Brap Brap Brap Brap
