oil temps
Started by Adam fc, November 18, 2009, 09:02:43 AM
Adam fc
these standard oil coolers...are they up too the job of bigger power??
have you tried testing it in hot water?
grinder
Quote from: Archbish;655175have you tried testing it in hot water?
LOL :D :D
:spank
The tightest man on earth
:Giggle
L18M
Quote from: Adam fc;655174these standard oil coolers...are they up too the job of bigger power??
upto 500bhp.
have a look through the fc3spro weblink i gave, they have LOTS of good info!
Quote from: L18M;655208upto 500bhp.
Here is what the silly FDs use to cool their oil:
Our ones run along the lengh of the radiator and are about 3 inches thick :D
L18M
Quote from: m1tch;655210Here is what the silly FDs use to cool their oil:
but some have 2 of them.
i was gonna go twin fd oil coolers but i was advised to stick with stock fc one
Quote from: L18M;655223but some have 2 of them.
Yeah, but 2 small thin oil coolers lol just stay with the stock FC one :)
Adam fc
excellent,ill probs change to some braided lines for it though.
Ive been thinking about a front mount intercooler.Having that stuffed in front of my rad,oil cooler and power steering cooler will this not make the ar run a tad hot with all that restriction in the way??
Im not lloking to go down the v mount route either.
Quote from: Adam fc;655263excellent,ill probs change to some braided lines for it though.
I have gone with an uprated top mount, has no lag at all :D keeps the temperatures nice and low, although there is a bit of heat soak if sat in town, it takes ages to heat up if its a good core :)
When I change the turbo over I will be going for a flat mounted intercooler :)
L18M
thicker rad (koyo) will help and proper ducting, you can also channel air from the hole in the bumper under the headlights in round to the back of the ic but infront of the rad.
cut holes into front bumper to get more air going to oil cooler.
easier said than done. well for me neways lol
dthebuk
Quote from: grinder;655162didnt i mention the water trick in post #2 ;)
think i learnt this bad boy technique from one of your older threads :wiggle
:burnout
grinder
its probably the easiest way to be honest ;)
im just not sure what will happen when you remove the line from the filter ped ??
does the oil filter hold oil all the time .. or does it drain back into the engine/sump over time ?
:Giggle
Adam fc
excellent well im bidding on a koyo rad and front mount at the moment.Ive got a gpsports front to go on and that has a large cut out in the front which i assume will be good for cooling.
Just wana make sure the cooling is up to the job before i go nuts with the power gains.
Adam fc
When i removed mine there was some oil spill but nothing a well placed rag couldnt handle:)
