Clutch Master Cylinder
Started by Sean, May 05, 2004, 11:21:03 AM
Sean
I\'m about to remove my clutch master cylinder, does anyone know what I need to do, cause as you probably all know by now, I\'ve a habit of breaking / loosing things that I try to fix!!!
HELP!
gilbert
Are you changing it or just taking the gaerbox out ?
If you are just taking the gearbox out then unbolt it from its mounting point abd then cable tie it out of the way.
If you are changing it then it does not matter if you brake it.
Sean
Thanx Gilbert. I had to replace the insides of the Clutch Master Cylinder, but when I started to tackle it, it turned out to be one of the easiest jobs I\'ve had to perform on this car. Just had a little bit of fun trying to source some more clutch fluid after I\'d done the job.
 (no fluid = no clutch = not being able to get fluid = bolloxed = I\'m stupid for not getting it before I start the job = I\'ll shut up now).
