is my engine blown ??
Started by rotary_rx4, September 25, 2009, 09:09:31 PM
goldk28611
Quote from: gavinnblake;652916hi m8 that my video of my rx7 yes ifits like that its a rebuilt yes my rx7 allows me rev but i had to pump the to throttle
How was the car running before you had that issue? or did it just come out of nowhere one morning?
gavinnblake
it happen all of a sudden i was comeing back from jm imports must dun about 3 miles i was driven the rx7 about 30mph in spray road when there was a pop from the exhaust rev dial drop down lost power but engine was stull running i give it a rev and there was no rev respomce i had to pump the throttle to get a rev respomce i lost compression on my rear rotary
have you dun a compression test
goldk28611
Compression test will be done tomorrow - I\'m hoping it\'s not the engine as the car was running perfectly before, (holding boost to redline, all temps etc OK too) other than the bouncing rev issue when back on my drive, but that was not present when starting the car for the last time when putting it back in the garage, even then it sounded as normal. HHhmmmm.
