EGI Rats nest removal
Started by j3d1, November 09, 2009, 01:06:51 PM
j3d1
Can anyone point me in the direction of how to remove as much of the rats nest as possible? I\'ve done a search but can find anything here. Thanks
Skifledanabit
[SIGPIC][/SIGPIC]
dthebuk
thought the rats nest was all the solenoid and pneumatic lines used for control over the turbo\'s?
:burnout
j3d1
I\'m looking to remove all the vaccum lines and things for reducing the emissions (I may have got the wrong name - rats nest) that sit ontop of the engine and connect everywhere. I\'m pretty sure they\'re not all needed?
Yep - you can eliminate almost all of it actually - if you aren\'t bothered by emissions and run a fairly clean engine and well tuned.
If your EGI has all the solenoids and stuff down the side near the oil neck - most of these are to control the air valve that sits on the lower inlet manifold.  However, there are a couple of others.  One thing on the EGI\'s that you will need to keep or arrange an alternate conrol for is the 6 port actuators and the VDI solenoid - you can eliminate stuff like Split air (if you have no cat fitted), port air and relief.  You can also get rid of the PRC solenoid - but that will mean having to route the vac line from the manifold to the fuel pressure regulator directly - and when you start the car warm you may need to nurse the throttle a bit for the first few secs.
Brett is your best bet for advice with the EGI engines.
j3d1
good stuff, I thought there was a way of getting rid of this lot. Any chance you can send me any links?
(or are there some for paid up members? ;))
