When going 850cc primarys
Started by pigeon, October 29, 2009, 08:03:24 PM
pigeon
Ok so i have decided to go for some 850cc injectors in my primary fuel rail. I remember reading that the fuel rail needs 3mm machining off the top. Well i have done that no problem, but im wondering if it also needs counter sinking like it was origionally, as the injectors dont sit flush like they origionally did as you can see from the pics.
Thanks for any input. Adam.
Quick question, have you already maxxed out the secondaries at 1680cc alraedy? :D
FD3UK
3mm is to much, its about a 1mm to be removed. The injector will be hitting the taper part of primary rail.
Ideal size is 52.8mm from top to bottom face.
Injectors need an extra 1.5mm O ring behind standard bottom O ring to make sure it engages in the bore.
pigeon
Quote from: m1tch;651252Quick question, have you already maxxed out the secondaries at 1680cc alraedy? :D
Lol no they are stock 850cc secondaries.
Quote from: FD3UK;6512533mm is to much, its about a 1mm to be removed. The injector will be hitting the taper part of primary rail.
I beleive there are two methods. One is to remove less and double o-ring and the other is to remove more, without the need to double o-ring. but can\'t find anything about whether it needs counter sinking if you take the remove more route.
Cheers for the info though dude.
