sva info
Started by davehg, May 04, 2004, 01:41:28 PM
davehg
hi people
im looking at buying a RX-7 from a guy on here but would like more info on the sva testing. ive spoken tio my local centre who say that i need the standard back box on it (can anyone lend me this in the bristol area please)
also is it just a case of changing the dial face from KMPH to MPH or does it need something to actually change the input???
will a small fog light bolted to the bottom of the rear bumper be enough to get it through?
sorry for all the questions
dave
hotstepper1973
hey there hope u get a 7 but if this in any help u can buy the de-limiter from a place which i will have to get back to u on but this acts as a conversion on your speedo from obviously kph to mph it and this also takes the restriction of the car ie limited to 112mph it is a small chip i had mine done by a auto electrician quite reasonable price that way also i am baffled as to you say that you have to change your back box as when mine went through it had a apexi exhaust on it, but i was wondering has your exhaust system gone all the way through. I think it is only a problem with your exhaust in case it is exceeding the noise regulations but i am not to sure.But one that i had a problem was the foglight basically the sva tester failed it on the fact that it was too low to the ground 240mm when it had to be 250mm this was a swine because i knew it had to be 250mm but when i had it fitted we measured it and the level was ok but on the day of the test he told me i had to have a full tank of fuel so that brought the level down to fail bar steward.
I will try and found out which company i used to source the de-limiter and foglight and let you know.
And finally i think you will need to get a new fuel cap for the sva test.
You only get one life live it
davehg
thanks mate thats a great help, any info on where i can get bits from with prices would be great,
hotstepper1973
right then the company you need to speak to is called eurospec 2000 and you can contact them on 01483236509 ask for mark he is ok and if you like tell him brian gave you his number that bna ellis on here he is the guy that helped me when i was doing mine ok good luck and you should come to rotorstock if get her.
davehg
no one is answering that number, all i get is a beep, is that there fax number???
hotstepper1973
no that is there tel no just so you know this is there website address there are a few details on there http://www.euro-spec2000.co.uk just keep trying ok sorry i cant be more help
