Quick two stroke question...
Started by Jim_rx7, October 18, 2009, 09:48:14 PM
Jim_rx7
Recently just finished my rebuild.
Decided to remove the OMP. Blanked off with a plate and the injector holes blanked off also.
Finished putting the engine in the car today and should be firing her up tomorrow.
Question about two stroke....
Does it matter what brand/type I use? I\'ll be buying it from halfords if that helps.
Also, how large is the FD3S fuel tank? Reason I\'m asking is if the gauge is showing 1/4 full - so I know how much two stroke to put in before I fire her up.
many thanks
I know prof runs marine 2 stroke stuff, as marine engines run at higher RPMs for longer periods of time, might be an idea to perhaps run 2 stroke in the fuel as well until you are happy with the setup?
