Have i brought the wrong HID kit
Started by rx7ben, October 14, 2009, 07:17:49 PM
rx7ben
I got myself a hid kit for my fd, but the thing is thay only work on high beam :2Mad Does this mean i cant use them or will the high beam on the hid"s be the same as  the low beam on the old bulbs.
batman
im guessing mate you have bought a single hid kit. you need the twin for and fd unless your using after market lights ?
rx7ben
Yeah im useing standard lights. Looks like i"ll have to get some more.
MaLicE
you need the h4 bulbs that do hi and low, some companies call them h4-4 or h4 bi xennon
L18M
be careful when you buy as some H4 have 1 bulb (does hi and low beam) and others have 2 bulbs (xenon for low beam and non-xenon bulb for high beam). the latter one is not as good.
probedb
You may have them wired in wrong. Normally the HID part would work on dipped even for single beam lights as far as I know.
trotter
FD standard light set up is to use dipped only, when you go to full beam the dipped get cut off.
I\'ve had to modify my HIDs so that all four (didnt want the hi/low beam ones) lights come on at once - looks tres cool!!
Work hard, play hard house :D
