Quick spark plug Question
Started by SCOOMER, October 01, 2009, 12:42:35 PM
SCOOMER
I flooded my FD recently so after removing the plugs i only went and dropped one and cracked the ceramic so need new plugs. Im wanting to change from 10s & 11s to BUR9EQP all round. But......Because its been mapped with colder plugs am i going to have issues changing to a warmer one?
Cheers Scott
AtomicRex
Why are you wanting to change to 10\'s and 11\'s?
Moving up actually is colder not hotter.
It is always wise to check the map, as the plugs you are running will create a much stronger burn.
We supply the BUR9EQPs as well as the racing 10s and 11s
http://www.mazdarotaryclub.com/forums/showthread.php?t=53025
SCOOMER
Quote from: AtomicRex;645304Why are you wanting to change to 10\'s and 11\'s?
Im running 10s and 11s at the moment and funds are tight at the moment thats why i was going to buy some cheap plugs to get me away. Just wanted to know if il be ok sticking 9s in alround for the long run or not.....?
AtomicRex
oops sorry
I should have read that a bit better.
I will wait to be told by someone who is more in the know about the mapping....but I would say that it would be fine going that way.
well if you want some BUR9s I have loads in stock :)
SCOOMER
Quote from: AtomicRex;645316oops sorry
No probs thanks for trying to help :) How much are your plugs BTW?
AtomicRex
£7.99 + VAT (£9.19) each + postage....but that isnt that much for just 4 plugs.
Hi Scott hope your well,
Don\'t worry 9\'s will be fine in your car to run all the time,
SCOOMER
Quote from: clive;645332Hi Scott hope your well,
Hey Clive,  thanks for that :Thumbs-up
Scott
