Good FD3S rotor for sale????
Started by antrosser, September 12, 2009, 04:09:53 PM
antrosser
As it says on the tin. I need a good condition rotor, weighting of D preferably.
Let me know if you are selling one )
Cheers all
antrosser
Well i have two Rotors which came from two different FD engines, thing is i don\'t know which of the Letters indicate the Weight stamp.
Can you tell me which Letter it is (there are a few different ones)
antrosser
There will only be one letter (Rating A to E I believe). The rest are for something else...no idea what though!! lol.
not 100% sure but i think i have a C (its slightly larger then the others)
antrosser
Slightly larger? Is there more than one letter between A and E? If there is  I have no idea which one it would be!!
You would have thought they would all be the same weight wouldnt you!! I wonder if the heavier ones help with torgue....hmmm
L18M
antrosser
Quote from: L18M;642941http://www.mazdarotaryclub.com/forums/showthread.php?t=57860
any help?
but they for 3mm tips and are off a S5 fc
Not sure the FC would fit in the FD. I have got some 3mm tips that are surplus to requirements tho, but I\'m going to stick with the 2mm I think for better sealing :)
Cheers for look tho matey
DR SCHNITZEL
I need a B. aint they all the same size just different weights?
davehg
All FD rotors are the same size but the weights vary and are stamped on them if you know where to look for the correct letter. A manual FD canhave rotors of weights up to one letter out either way ie A and B but not A and C. It is recommended that Autos are the same weight though.
BlitzBoy
i have two in my garage i will check tomorrow
Rotorstock winner 08,09
New Project
"el fénix" RX2 by Mark & Mark
antrosser
DR SCHNITZEL
