URGENT commander question...
Started by trotter, September 16, 2009, 10:55:29 AM
trotter
guys / gals....
After an almighty argument with ParcelFarce, my commander finally arrived this morning!! :D
Now assuming that I have bought the right one, is there anything that has to be done before I use it (its second hand) ie: resetting it back to original settings?
I know there is a setting for this but the manual isnt very clear!! Will this reset the PFC as well? I don\'t want that to happen!!!
cheers
G
Work hard, play hard house :D
Ada7
As far as i know it should just be a matter of plugging in the commander and away you go. The setting are in the ECU and all the commander does is show whats going on.
Plug it in and see what happens :D
Adam
I AM HERCULESIAN
trotter
cheers, it just hangs at the Logo
Methinks an ebay complaint "not as described" is coming.... :( :(
Ada7
Make sure its the right commander for you year of ECU. If you search on here you\'ll find threads with the codes on for which commanders work with which ECU
Adam
I AM HERCULESIAN
trotter
Quote from: Ada7;641848Make sure its the right commander for you year of ECU. If you search on here you\'ll find threads with the codes on for which commanders work with which ECU
Adam
just worked out i need a \'z\', not the \'x\' that i got.....
hence the new thread in \'for sale\' LOL
peterwolds
Quote from: trotter;641851just worked out i need a \'z\', not the \'x\' that i got.....
T no wonder its the wrong one - toooooooooooooooooo much ale at the weekend,presume you didnt see the fireworks from inside truscador :cheers
:Typing Pete
trotter
Quote from: peterwolds;641860T no wonder its the wrong one - toooooooooooooooooo much ale at the weekend,presume you didnt see the fireworks from inside truscador :cheers
Yeah, was a wee bittie wasted! :P
You and the missus have a good night?
peterwolds
Quote from: trotter;642169Yeah, was a wee bittie wasted! :P
cracking night cheers,also went back on  sunday for the clipper race was packed,red arrows display was stunning,had a cheeky 1 on way home at timber dock
:Typing Pete
