which is the spare nipple?
Started by mike_106gti, August 26, 2009, 08:35:56 PM
mike_106gti
as above which is the spare nipple on the top of the inlet manifold and should one of them have a bung on it?
installing new boost gauge incase you were wondering
Nik da Greek
Don\'t think it really matters which you use, dude, so long as the largest one goes to the brake servo.
mike_106gti
so shall i just cap one of them with something?
Nik da Greek
Yeah, they generally just have a little black rubber bung over the end IIRC. I guess if you\'ve not got that, the old bodge of a short bit of vaccuum line with a bolt the right size screwed into the end to make it airtight\'d work?
shaunwil
There are a couple on the left side of the plenum, just over the turbos. Blank off any not used !
Just make sure you use good quality vac pipe or it won\'t last long. My first pipe welded shut under vacuum and heat :Giggle
Shaun
mike_106gti
shaunwil
Best Bodge is to get a partly threaded bolt and cut the thread off. Works very well !
Shaun
