how do you take out the air pump
Started by johnnycrx7, August 28, 2009, 08:38:39 PM
johnnycrx7
guys im looking to take out my air pump. i think i dont need it and the engine pay looks so much better witout it.
SiH
You need either a shorter belt, or a set of air pump elimination pulleys, you\'ll also need some block off plates for the holes it leaves.
Then it\'s jsut a case of undoing all the pipes that go to it, and blocking them up.
Bear in mind though  that if you still have the standard cat then you\'ll kill it pretty quickly with no air pump, so it\'d be advisable to fit a decat. And if you have a decat you really need a remap, for which you need a remappable ECU... It starts getting pricey!
