Fuel damper?
Started by m1tch, August 16, 2009, 10:39:24 AM
Hey everyone :) im going to get my 1680cc injectors fitted to my secondary rail soon, which are a tad larger than my stock 550s :rollin
I just need to ask about the fuel damper, I know this will now be no good as its only ment to be able to dampen the stock injectors and so can\'t cope with the larger ones, would I need to fit a fuel pressure regulator to sort this out?
Yes you will do away with the stock damper and run a pressure regulator  in line preferably with a gauge so you know whats going on
Ok cool :) *adds to list of things to buy* lol
Good time to change to the parallel fuel rail setup...
http://www.fc3spro.com/TECH/MODS/FUEL/fsystem.htm
I would love to change to a modded fuel system, but my budget won\'t strech that far :( unless there you can list the minimum of parts I need?
