turbo system
Started by luckynumberseven, July 21, 2009, 03:49:17 PM
luckynumberseven
:3ConfusedThe turbo system goes into twin mode when you pass the transition point (about 4500 rpm at WOT, later for partial throttle). It does not return to single mode until you go below 3000 rpm. So, if you go past the transition and then coast down to 3100 rpm or so and floor it again, it will be a little slow building boost because both turbos are still on-line. It is supposed to work that way.
This was gleaned from a page i was reading when trying to figure out wha was wrong with my engine my turbo acts like this i wondered if it can be adjusted out.Is it meant to be like this.
Not sure how that would work because the Second turbo needs Boost pressure to open the Solenoids/Valves to create Boost so if you are in Neg pressure surly even if its for a split second the first turbo would have to spool up first?
