Blitz Induction Kit Help
Started by darknight7777777, July 11, 2009, 09:37:38 PM
darknight7777777
Hi,
i brought a Second hand blitz induction kit and i have everything except one plug/bung, what i wanted to ask does anyone have a copy of the instructions or scan of them dont matter if they are in japanese all i need to know is where the 2 plugs/bungs go and the brackets also and where the plate attaches to. i can pay £10 by paypal for a copy.
thanks
Akash
darknight7777777
leon
Get a picture up of how its currently is or what you think is missing, im sure one of us can talk you through on whats missing, or what to do. It won\'t be much disimilar to the HKS or Apexi installs.
Chances are:
You have two connectors for the pipes, both of those will go to the pipes that run to the back of the engine (Cant remember what they are. not touched the twins in ages! ones waste gate though) You will have a third pipe from the air pump dangling. Your best off putting a small filter on that pump, and some form of baffle to stop it Mooooing!
I woof in your general direction.
darknight7777777
I have figured out how to connect pipes as the are connected in stock pipe locations. And I think I got the bracket worked out the only thing is out of the 3 smaller pipes I know which one connects to the BOV which leaves 2. Which pipe goes to the air pump as I have a metal pellet that goes in it. Then it\'s done.
batman
