What is that graph on the pfc
Started by rx7ben, July 29, 2009, 06:31:31 PM
rx7ben
You no when you got you readings up on the pfc commander and you push next. What is that graph that comes up because i havent got a clue what it means. :confused:
AshRX
rx7ben
Aubec
I think he means the ten second graph of the currently displayed items in Monitor... In which case, it\'s a graph of your currently displayed values against time. It\'s easier to read if you\'ve only got one value displayed at a time, e.g. You can check your boost pattern etc.
Aubec
1995 UK Silver FD
NurburgRob
I think it displays the value that you have as 1, i.e. the top value if you have it set to show 8 or 4 values.  I have mine set to Injection Duty as the first value and the graph only shows that when I set it to that display.
Aubec
Quote from: NurburgRob;630800I think it displays the value that you have as 1, i.e. the top value if you have it set to show 8 or 4 values. I have mine set to Injection Duty as the first value and the graph only shows that when I set it to that display.
Curious... mine displays both, or all 4 or all 8 depending on the number of channels I\'m watching.
Aubec
1995 UK Silver FD
NurburgRob
