Anyone have MMR Rear Camber Links?
Started by N22CK_C, July 03, 2009, 02:26:56 PM
N22CK_C
Hi all,
Anyone have MMR Rear Camber Links fitted to there FC if so don\'t have a picture of them fitted?
Just so i\'m clear on which way to put mine in... when they get here:Giggle
Nick
N22CK_C
surely there is picture somewhere of these fitted...
Jürg Hensdiek
Hallo,
Have you also purchaced the link arm spherical bushing? If you are using stock or other aftermarket bushing you will have issues.
Greetz,
J
N22CK_C
No i\'m going to be using stock bushes..
Quote from: MMR-Direct.comTHESE LINKS ARE NOT COMPATABLE WITH DELRIN OR POLYURETHANE REAR CONTROL ARM BUSHINGS. THEY MAY BE USED WITH OEM RUBBER CONTROL ARM BUSHINGS OR WITH MMR SPHERICAL CONTROL ARM BEARINGS.
:confused:
