blown my fd i think
Started by francovel3, August 30, 2009, 03:24:07 PM
francovel3
ok i was driving my car in the morning then decided to give it a little boot, then after releasing the throttle the car started to fart and when i gor to the light on idle it sounded like a trucktor and was idleing hust over 1000 rpm.
does that sound like its blown or have i spun a seal any advise would be helpfull?
POWER GAINS
karl_tate
just over 1000rpm is normal is depending on your engine setup, what was it before??
on the passengers side, above the oil filter there is what is called a map sensor that is bolted to the bulkhead. check the pipe going to it.
____________________
XBOX GAMERS TAG --- tatey1985
michaelb
Mate
I am in North London ( Crouch End)
Where are you ?, I could help you out, but it looks like an identical problem I had on my FD - stepped on it in first gear laid off the throttle at around 7 000 revs and I had the symptoms like yours ( chipped a rotor)
Took it to Powergains Motor Sport (Romford) and Kerim had to re-build my engine    (about a year ago)
Regards
Michaelb
francovel3
just checked the map sensor and it looks fine but i just checked the oil and it was below minimum i cant belive it i always check the oil every weekend but you could be right about the rotor, whats the best option for me shall i remove the engine my self to save some money and i also have a single turbo waiting to go on either way ill have to save for abit
POWER GAINS
michaelb
Quote from: francovel3;638498just checked the map sensor and it looks fine but i just checked the oil and it was below minimum i cant belive it i always check the oil every weekend but you could be right about the rotor, whats the best option for me shall i remove the engine my self to save some money and i also have a single turbo waiting to go on either way ill have to save for abit
Can you drive the car?  I drove mine on 1 rotor (sounds exactly like a tractor) to Kerim\'s to have an RX7 specialist opinion...he is a superb mechanic
You may just be lucky but prepare for the worst...
Incidentally, if you have a single turbo with all the auxiliarys (you will need a few) you will be presently surprised at Kerim\'s prices
Equally, you will sell some part which will become redundant when you go single thus recovering some costs
He re-built my engine, polished the exhaust ports, set up some hard pipes and the cost was shockingly good
I am not sure you will save much by taken the engine out in the first place plus whatever chipped the rotor must be corrected or it may finfish your new rebuild in minutes
Nothing like an RX7 specialist mate...
Regards,
Michaelb
francovel3
i can remove the engine my self and hand it to jaydee if he can do it for me if thats ok?
POWER GAINS
francovel3
Quote from: michaelb;638500Can you drive the car?  I drove mine on 1 rotor (sounds exactly like a tractor) to Kerim\'s to have an RX7 specialist opinion...he is a superb mechanic
Regards,
Michaelb
yea i spoke to him the other day i will see what happens in the next few days
POWER GAINS
bnaellis
Quote from: francovel3;638477ok i was driving my car in the morning then decided to give it a little boot, then after releasing the throttle the car started to fart and when i gor to the light on idle it sounded like a trucktor and was idleing hust over 1000 rpm.
Sounds more like lower intake manifold gasket has gone. I don\'t recall ever seeinga n engine on one rotor idling as high as 1000rpm. I would check that for leaks before pulling the engine.
rgds
Brian
hairyhoover
Yep brians right!! The revs tend to drop and the car shakes like fduk
