Single turbo kits....
Started by suba, June 12, 2009, 11:31:10 AM
BlitzBoy
you will get positive boost , but with stock ports you wont be seeing full boost eg (1 BAR) until around 4.8 - 5K.
On stock ports  if you want fast spool go for a T04E.
But if you are looking at doing big porting on your engine in the future then go for one of these bigger turbos
Rotorstock winner 08,09
New Project
"el fénix" RX2 by Mark & Mark
suba
Ouch - 1 bar by 5,000 rpm is way too slow - even if I was to go for this option with the aim of porting the engine in future, I could not live with that for now.:(
Single Turbo time!
BlitzBoy
yep it is a big turbo, same with the GT35 that wont be at full boost until way over 4k with stock ports
New Project
suba
I was led to believe by a couple of people that the GT35 would be similar to the T04E in terms of spool / response on the stock ports?
Single Turbo time!
Ed_RX7
Quote from: BlitzBoy;615758you will get positive boost , but with stock ports you wont be seeing full boost eg (1 BAR) until around 4.8 - 5K.
CHURCH!!!..................:chat
Edrx7Parts
07531 669 768
Also of
overboost
Quote from: Speedline Imports;615734TO4Z complete kit is £1500, Also available is a high flowing exhaust system for an extra £300 which all came from blitzboys old setup and was a proven 450+rwhp!
hmmm... tempted:mmmm
What about street port? Will you see boost around 3500rpm?
Jit
street port?? youre not opening up the engine already are you Jason???
overboost
Quote from: Jit;617137street port?? youre not opening up the engine already are you Jason???
Not yet... but I\'ve doing a lot of thinking on the choices I have got.
I\'ll have to get a power fc as I am still speed limited at 180km/h... which is annoying enough on a small track in Brands Hatch but in Bedford I have to crusie for the 3/4 of the main straight.
So I\'ll have to deal with the speed limit thing...might as well get a power fc and map the car. Then I\'ll be better off if I have bigger intercooler, down pipe possilbely fuel pump as well to max out the standard turbos.
Then again, V mount intercooler will be an overkill for a standard turbo setup but if I go for sm or fm I\'ll need to replace them for a V-Mount as soon as I get a single turbo set-up, which will happen anyway in the not-so-far-away future.
So think about going single now... especially I have always fancied a TO4Z from the RB26 days
chopper2k22
Quote from: overboost;617142Not yet... but I\'ve doing a lot of thinking on the choices I have got.
V mount is great for twins, lower intake temps the better! i dropped the boost after putting the v mount in as i run out of injector duty and made 20bhp more just on getting rid of the stock ic
AtomicRex
Or even a front mount :)
There is still a divided camp on whether the V-Mount is better than the Front mount.  Personally I have ditched our V-Mount in preference of a very big FM and Radiator in the vertical position
antnicuk
Quote from: AtomicRex;617173Or even a front mount :)
oooh controversial,   what made you dump the V mount John,  I have always found a vast improvement.
antnicuk
Welcome to the world of RX7\'s   :Thumbsup!
:Laugh
AtomicRex
Quote from: antnicuk;617180oooh controversial, what made you dump the V mount Jon, I have always found a vast improvement.
The performance on the first set up was useless....I would see intake temps of close to 70 deg C, but moving to a bigger set up, which is still for sale if anyone wants it, I was seeing between 10 and 18 deg C.
However watching the Race cars in New Zealand, not one had a V-Mount, all were running Front Mounts.  Also I was nurfed off the track and did some grass tracking before managing to make it back onto the track...quite fun at 120mph!  The car was fine to race other than a combination of the front splitter and V-Mount had acted as a lawn mower, and the entire space between the radiator and intercooler was packed with grass...end of race :(
We have had some intercoolers made for our new cars...and these use a much larger gap between the turbulators.  This should allow more air to flow through and so keep the radiator cooler.
antnicuk
interesting about the guys in NZ,  i spose if you make the front mount and rad big enough, then its gonna work
you still racing john?
AtomicRex
Soon to make a come back yes :)
Hopefully we will have the workshop up and running to full steam again, and now with the new members of staff it isn\'t going to be long!
Have a few customer cars to get ready but then can start concentrating on our cars again.
We do have TonyC gallantly testing our new parts though...so hopefully they will be doing a good job at a circuit near you soon!
